Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • UIFlow 2.0 Suggestion
    4 Votes
    3k Views
  • UIFlow Desktop 1.0.17, Custom Block Problem?
    6k Views
    stanelyS
    @ajb2k3 :( hope 2.0 is comes out soon.
  • M5Paper / Touch only working on USB power
    14
    21k Views
    B
    Hello, i can confirm that touch is now working with firmware 1.9.2 in battery mode. Thanks @all for the help.
  • Frequency measurement with hardware interrupt handler
    8
    14k Views
    stanelyS
    @Amani , I also need to measure frequency using an M5 Stack Core 2. I was looking at your code and wondering if you ever solved this problem? I see that you're using a counter that's incremented in an interrupt handler. How do you get the frequency from that? The way I understand Micro Python interrupts is that they're soft and give you jitter of some milliseconds, like over 2. Because the M5 Stack UIFlow runs on top of Micro Python, it does not seem likely that interrupts with adequate resolution are possible. You'll be lucky to measure a 500Hz signal. But I'm very interested to hear if you came up with a solution. I'm planning to solve this problem with a frequency to voltage converter. TI makes a low voltage part, LM331. The output is a voltage proportional to frequency that can be input to an ADC pin. Here's a link to the datasheet, https://www.ti.com/lit/ds/symlink/lm331.pdf I don't see another way to solve this problem using an M5 Stack. I'm hoping you found one that you can tell me about. Thanks
  • SDCard does not work on M5Stack FIRE.
    14
    26k Views
    felmueF
    Hello @romor001 I've just retested it on my M5Stack Fire running UiFlow v1.9.1-fire firmware and I can list the content of the SD card just fine. Blockly code: [image: 1644921581552-uiflowm5firesdcard220415.png] Micropython code: from m5stack import * from m5ui import * from uiflow import * import os setScreenColor(0x222222) print(os.listdir('/sd/')) Make sure the SD card is inserted before you power the M5Stack Fire as it is mounted while booting up (mounting code is in boot.py). In the log you'll see this: SD card mounted at "/sd" Thanks Felix
  • Pahub not recognized on port SDA21/SCL22 (uiflow 1.9.1) - help needed
    7k Views
    felmueF
    Hello @Arno I am sorry, I cannot help you on this one - I don't have the EXTEND I/O unit to test. That said, you might get some idea how to talk to it through I2C by looking at the Arduino example? Thanks Felix
  • UIFLOW blocky missing IMU's "get Z" block
  • UIFlow Custom Block Maker Missing Components
    6k Views
    ajb2k3A
    The expect this is due to the api upgrade
  • ERR_INCOMPLETE_CHUNKED_ENCODING on flow.m5stack.com
    4k Views
    T
    Looks like it is back up now
  • CardKB ESC from CORE2
    3k Views
  • ADS1100 Hat with Core2
    3k Views
    felmueF
    Hello @brvus76 according to the schematic the hat needs 3.3 V. Thanks Felix
  • Where did rectangle go? Core to Tough
    1 Votes
    5k Views
    Hello @tgeddings I don't know UIFlow, but there are bar graphs in the Arduino IDE. The LCD has a progressBar command. https://github.com/m5stack/m5-docs/blob/master/docs/en/api/lcd.md progressBar(int x, int y, int w, int h, uint8_t val); [image: 1643144585697-m5_vs1053s.png] LVGL has many display functions as well as bar graphs. Light and Versatile Graphics Library:https://lvgl.io/ UIFlow is a port of LVGL, and the addition of functions is always delayed.
  • Guidance on running multiple programs
    9k Views
    J
    @robalstona thank you for the guidance as it saves me a lot of trial and error. Appreciate it.
  • UiFLOW. I2C Programing
    8
    1 Votes
    12k Views
    bschwahnB
    @arno Thanks Arno for the push in the right direction. I was able to get this to work on my Core 2 EXCEPT using G21 or G22. I will write up a tutorial on try to find a way to post/share. Thanks again Arno!
  • UIFlow : how to select multiple blocks ?
    4k Views
    m5stackM
    unless the block is stacked together. else you can't remove or select them at the same time.
  • 0 Votes
    4k Views
  • UIFLOW MQTT with thinger.io
    7k Views
    A
    @arno Does anyone know a free provider for MQTT with good representations of measured values?
  • How do I upload python code for Fire v1.9.0?
    3k Views
    W
    Thonny and Micropython run great together. Here is a link where you can download different firmware. You should also flash the firmware via Thonny. It is very simple. https://github.com/russhughes/ili9342c_mpy
  • Missing "import module" definition at UIFlow 1.9.0 at new Project
    4k Views
    F
    @felmue Thanks for support, problem solved.
  • M5Paper - Uploaded via Flow but nothing showed on the screen.
    3k Views
    J
    Thanks, i also realized that i have uploaded wrong Core firmware, but both was needed to make solve my issue.
