Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • Core 2 MQQT fails to publish on topic
    4k Views
    C
    @ajb2k3 started with this https://youtu.be/5RozKI-3i4Q.. My project is to monitor power , security , humidity , temperature and water leaks at a remote business premises . Thats part 1 Part 2 is to push actions over MQQT based on reports . Will be using a Stick C plus for sensing and Core 2 at home plus Andoid app for real time alert.
  • How to use the ExpPort For Core2 module
    4k Views
    ajb2k3A
    Ports B and C are not controlled by the board, they are connected directly to the bus and handled directly by the core. As to D and E which are handled by the base. Ports B and See only. become available when you select units that require ports B and C
  • Core Ink battery status
    8
    10k Views
    E
    @ebksuper By digging the web I found a python script what translates to this in UIFLOW / BLOCKLY. I translated this the best I could to UI FLOW. The mAh are of the specs of CORE INK and my full loaded battery gave out on "get battery voltage" 4242 asuming this translates to 4.2V. So far it spits out reasonable numbers. I am testing if this is accurate enough to be an indicator when to recharge. Please comment if you found errors or have a more elegant solution to get a Batters Status. Thanx : ) [image: 1687683614236-uiflow_block_bat-resized.png] #uiflow #battery #coreink #m5stack #core
  • Accessing decoded JSON array
    6
    14k Views
    ajb2k3A
    @rmorgan please dont double post.
  • JSON AWS Topic decode
    ajb2k3A
    Is your Core connected to the WIFI ? By this I mean do you have the SSID and password blocks in your code? I cant tell from this snippet what your code is doing and need to see the full code in order to help.
  • Can't Run the Config util
    11
    11k Views
    J
    @holofloh Thanks very much for this info.. Yes I agree, my Windows 11Pro has no facility to set a VID or PIN in the FTDI driver settings but it does at least appear to be the correct / identical driver as is recommended by the docs on this site that I am now, and have been using for this M5StickCPlus V1.1 device..
  • Uiflow 2 wireless conected with uiflow
    1k Views
  • ATOM S3 with UiFlow - module M5 or M5Stack
    5k Views
    ajb2k3A
    @forestial I'm working on the docs at the moments and currently logging the API's but as you noticed, it is hard work to find them.
  • M5STack Tough in reboot loop when using UIFlow - Duplicated post
    4k Views
    I
    Thank's that solved it!
  • i2c library bug
    4k Views
  • 0 Votes
    3k Views
    Z
    Thank you! As it turned out, the main problem was that if in a program on UIFlow 2.0 (block mode) you create a variable named "state" and assign it 0 during initialization, then the controller starts to behave inappropriately (hangs, new programs either do not load or load but do not work , there are problems described in the previous post). It only helps to re-flash the controller using M5Burner and load into it a program in which there are no omissions of a variable called "state".
  • This topic is deleted!
  • How to save the last API key?
    5k Views
    Matej's WorkshopM
    Ohhh! Okay. Thanks.
  • "Unknown wifi error 0x0005"
    5k Views
    Matej's WorkshopM
    Hello, 8 months and still no reply!? Could you please send the code or is it already fixed?
  • Managing UIFlow buttons which disappear from screen but still exist
    ajb2k3A
    Not unless you leave UIFlow and use Micropython Directly with the VSCode, Thonny, or Mu editors.
  • Remote+ update values from m5stack core2 back to web ui?
    1k Views
  • Centre a label on M5Stack
    4k Views
    ajb2k3A
    @holofloh wow, I have never considered this, thanks for posting. I will add it to my guides.
  • 0 Votes
    3k Views
    D
    I have the same problem: yes - flashed firmware yes - wifi is setup (I set it up in m5burner the same way it's been working for lots of other devices, am I missing a step?) maybe it can access the UIflow2 server - how can I tell? yes - I'm trying to use uiflow2, not uiflow1 in the browser yes - I've looked at the connection settings, can't manually add it using the mac address, have no way to find the token (doesn't show up in m5burner the way old devices do)
