Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • This topic is deleted!
  • substring substr get part of a string
    3k Views
    H
    I was looking for this for 2 hours and after posting I found a solution by chance after 5 min. I will leave this with my solution if someone have the same problem later. this page show how it is done in python: https://www.freecodecamp.org/news/how-to-substring-a-string-in-python/ now I started trying to find any function in UIflow that could replicate this and... "bytearray in list xxx get sub-list from # to #" actually writes this code!
  • Monitor serial output in Uiflow
    13
    19k Views
    ajb2k3A
    In Uiflow/micropython you use the "print" command to send data to the serial console.
  • 0 Votes
    ajb2k3A
    That is because the PIR sensor is a port B device (black connection and by default is assigned to PortB, however, when you select the Unit In Uiflow2, you have the option to change the port.
  • Core2 UiFlow
  • Core2 resets when recoding from build in microphone
    8
    3 Votes
    10k Views
    K
    I just tried to record a simple .wav file via the built in microphone on my core2 with the M5Go Bottom2 using the blocky 'record to file' block. I am using UI flow 1.12.2 on my core2 and yes it does record and I can play the .wav file back but even at max volume of 6 the sound is very faint.
  • Compilation error for a project using SD card
    5k Views
    C
    Fully agree
  • No longer able to pair Core devices with UI Flow
    1 Votes
  • Difficulties with Pa HUB
    3k Views
    C
    I am surprised that none of the 109 viewers proposed the proper way of doing. Or maybe the PaHub is not their concern ? Anyway and for future beginners who could face the issue. 1)There is no need to add the PaHUB as a component as with the other I2C captor 2) These captors must then be declared as PaHUB and not as port A
  • Removing the UIFLOW menue on Tough
    9
    10k Views
    P
    @insaneLX Yeah, it has been fixed. please send a video on bug issues
  • how to set an image as background in uiFlow2.0:
    4k Views
    S
    @ajb2k3 I tried this lcd.clear() # Draw the image as the background lcd.image(0, 0, 'res/img/icons8-bluetooth-48.png') I tried this but I got this error un the screen Traceback(most recent call last):
  • coreInk can but uiflow doesnt
    3k Views
    ajb2k3A
    @ebksuper You use the Execute block for external API's or premed Micropython libs.
  • round to one decimal in UI flow
    5k Views
    C
    @riddsprojects Thanks. Glad to have learned something, works well indeed
  • Load images on M5Paper in UIFlow
    12
    19k Views
    I just got my M5Paper today, so this is very timely info for me, thanks!
  • How to interrupt a program saved on M5 Stack Core 2 ?
    4k Views
    C
    Thanks for the answer. So what I thought to be a last chance solution becomes the rule. In the videos and tutorials I have been through so far, this question has never been raised. One is told how to download a program to the device starting from scratch but never how to download program number 2..
  • M5 stack core 2 is disconnecting
    11
    9k Views
    @ajb2k3 said in M5 stack core 2 is disconnecting: America is trying to block Chinese things at the moment. :/ [image: png-transparent-face-emoji-eye-roll-whatever-eyes-thumbnail.png]
  • Modbus Master crashes and missing documentation
    6
    7k Views
    P
    Hi, @insaneLX [image: 1688369012974-5545b634-1765-460d-a5c1-c3d1ae46fd74-image.png] 0xff00(ON or 1) and 0x00(OFF or 0)
  • RGB Leds Crossfade
    3k Views
    H
    This is not an Uiflow specific solution. Try as following: Decide how many steps you want from start color to end color. e.g. 10 steps find the step size from start to end color e.g. you want from value 100 to 200 (difference / steps) = step size 10. loop for the number of steps and increase/decrease the value with the calculated step size.
  • Program update remotely
  • How do you send an HTTP GET or POST in UI Flow
    9k Views
    X
    @ebksuper Hi bro, I'm having the same problem. That's why I am here and noticed that you are having the same problem. After a few hours of trying, I finally got the data I wanted. I would like to share my solution here. Maybe it will help you, or not, either way, it's worth a try. [image: 1f4748de783ec.png]
