Subcategories
    125 Topics
    A
  • 212 Topics
    Y
  • 11 Topics
    A
  • Enable "back button" or "cancel button" in UIFlow main menu on device
    7k Views
    P
    I'm not sure if this helps, but when you are in M5Burner and you flash your Core2, next to the "Burn" button there is a "Configuration" button. In the popup, if you change the "Start Mode", does that get you out of the UiFlow screen on the Core2?
  • Using the Set Bit Block
    5k Views
    U
    Thanks - elementary error on my part. Problem resolved. Allan
  • IUFlow SD Card and Unicode.
    6k Views
    C
    @jchipjonty Thank you for your response. You are absolutely right it doesn't look very good. It looks like all text is in bold 12 and accented characters in plain text 10. Not a very elegant solution. Regards Carles
  • This topic is deleted!
  • UIFlow and ESP-now, error
    uiflow
    10k Views
    A
    Hi Dragon. Picking up this thread because I ran into the same problem. Caused by an empty value when out of sync with the sender in a P2P network transmission scheme (not ESP related but similar). Resulting as "None" for a value that should be converted into an integer used in an if/else process. I solved this by putting the if/else in a try/except statement and settting the except(ion) to a failsafe value until sync. [image: screenshot-flow-m5stack-com-2021-03-02-21-27-11.png]
  • How to control the speed of 180 degree steering gear in uiflow
    3k Views
  • Problems with READING serial data thermal printer
    1 Votes
  • How to power M5Core2 from module?
    6
    12k Views
    felmueF
    Hello @Elektron good find, thank you for sharing. It is interesting that in your case the 10k pull-down resistor already in place on N_VBUSEN wasn't strong enough (with GPIO0 set to float) and you had to configure GPIO0 to pull that line low actively. Makes me wonder if something has changed electrically inside (newer) M5Core2? Happy Stacking! Felix
  • M5Paper Multiple screen layouts
    1 Votes
    5k Views
  • UIFlow for M5Paper
    16
    1 Votes
    31k Views
    ajb2k3A
    oserror 118 is an issue with Micropython. from what i can tell, its an issue baffling the main MP devs.
  • Error 426 when making GET request
    3k Views
    E
    Thanks for the reply. You’re right that it’s the server response. In urequests, HTTP/1.0 is hard coded which is why the server returns that error. The API calls haven’t changed, I can make the same requests without issue via other REST clients or using the standard Python requests module. The issue is with the way only HTTP/1.0 is supported. What I’m trying to understand is if there is a way to make a request using HTTP/1.1 or above so I can avoid this? I’ve tried just changing it to 1.1 in the urequests module but sadly it doesn’t appear to be that simple!
  • Console Log with UIFlow
    4k Views
    ajb2k3A
    If you wan't console feedback, UIFlow runs on micropython ( I am in the process of logging this) and so using Thonny is what I would advise as the code can be copied from UIFlows python window and pasted into thonny before saving to the device.
  • Check SD Card Status
    8k Views
    felmueF
    Hello @SE thank you for sharing. The answer is not really surprising though - the required SDCard detect pin is not connected at all according to the schematics of M5Stack (Fire, Gray, etc.) and M5Core2. Interestingly it is connected in M5Paper, so SDCard detection should be possible there. But before you get your hopes up - SDCard support is not available yet in the UIFlow alpha version for M5Paper. Thanks Felix
  • UIFlow Github project?
    6
    13k Views
    B
    @world101 survey filled
  • HEX RGB LED Board Support in V 1.7.X
    5k Views
    K
    Thank you! I started to click on that, but I wasn’t sure. Thanks!
  • Send AT Command va UIFlow
    16
    33k Views
    T
    @world101 Uhh, sorry. Here the english version... [image: 1612533606629-bildschirmfoto-2021-02-05-um-14.59.10-resized.png]
  • How to use the RGB LEDs of FACE II ?
    8k Views
    ArnoA
    I finally found the problem ... putting the screws on my FACE II it works. Probably a false contact
  • Rel. 1.7.0 COM.LTE network configuration
    9k Views
    T
    Thanks, indeed the root cause was an old version of M5Burner, which I did not realized there was a newer one. Once updated, then the configuration panel showed also the APN settings and the UIFlow firmware booted successfully with the LTE connectivity
  • ESPNow UIFlow - communication stopps after 10 messages
    9k Views
    R
    The set.pmk function is used to "encrypt" data transmissions, you set the same key in the transmitter and receiver. I have not had the opportunity or need to test if it works. You can find a library for arduino esp-now on the internet. Practically the functions have the same or similar names as those in python. I think the easiest way would be to send from the transmitter all values separated by commas as text and receive them the same way. in uiflow or in python using split function which will make you a list with separated values Lists -> make list from text with delimiter. As a delimiter you set your separator character e.g. "," Then you read each value with Lists -> in list ... get # item number Translated with www.DeepL.com/Translator (free version)
  • UIFlow does not load .m5 file, program crashes (Ubuntu18.04)
    4k Views
    ZontexZ
    Hi, This is a bug we are aware of and trying to get it fixed ASAP. If you need to use UIFlow in ubuntu, id suggest to use flow.m5stack.com for now
