Update: I found the shadowed URL by removing a variable connected to the http_request block. At first, I directly specified the API key as a part of the URL, then replaced it with the variable.
I was looking for this for 2 hours and after posting I found a solution by chance after 5 min.
I will leave this with my solution if someone have the same problem later.
this page show how it is done in python: https://www.freecodecamp.org/news/how-to-substring-a-string-in-python/
now I started trying to find any function in UIflow that could replicate this and...
"bytearray in list xxx get sub-list from # to #" actually writes this code!
That is because the PIR sensor is a port B device (black connection and by default is assigned to PortB, however, when you select the Unit In Uiflow2, you have the option to change the port.
I just tried to record a simple .wav file via the built in microphone on my core2 with the M5Go Bottom2 using the blocky 'record to file' block. I am using UI flow 1.12.2 on my core2 and yes it does record and I can play the .wav file back but even at max volume of 6 the sound is very faint.
I am surprised that none of the 109 viewers proposed the proper way of doing. Or maybe the PaHub is not their concern ?
Anyway and for future beginners who could face the issue.
1)There is no need to add the PaHUB as a component as with the other I2C captor
2) These captors must then be declared as PaHUB and not as port A
Thanks for the answer. So what I thought to be a last chance solution becomes the rule. In the videos and tutorials I have been through so far, this question has never been raised. One is told how to download a program to the device starting from scratch but never how to download program number 2..
